The texture can seem washed out if the scene lighting is too strong so try dimming the lights in the model settings to check the texture is loaded correctly. Incorrect mapping can also produce unwanted results. This blog post covers everything you need to know for getting the textures right.
Hello Pavel, this is the same model , as in the other thread, and it seems that it has to do with the geometry. Now the texture loads fine but not the geometry
