Hi all,
Firstly want to say I have raised this issue directly with Enscape with no resolution since September so wanted to ask here as well to see if anyone has any ideas.
Using Rhino7 in certain models (possibly where worksharing is being used) when launching Enscape the folder C:\users%username%\AppData\Local\Temp\McNeel\Rhinoceros\V7\Texture$Cache$ slowly builds with black and white tiff files. Once complete the Enscape window shows the model. The issue here is two things; For example in the model I just tested (which admittedly is large) this cache grew to 105GB so Enscape takes a long time to load whilst this happens but also if the user has limited disk space the machine grinds to a halt.
I don’t know if this is an Enscape or Rhino issue but there are combinations of Rhino and Enscape where this behaviour doesn’t happen. Those are, Rhino 7 with Enscape <3.5 & Rhino 8 with Enscape 4 (preview). So any version of Enscape 3.5 has the issue in Rhino 7 but I can’t replicate it in Rhino 8 however only the Enscape 4 preview loads in Rhino 8 so I can’t fully test.
We have found one workaround in Rhino which is the main reason to post here, if the material type is changed to Enscape on all materials then this doesn’t happen.
Sorry if this is not clear, anyone got any ideas?
Thanks
