I often observed the following problem: suddenly when you enter text on grasshopper this text is entered in rhino instead of being entered in grasshopper for example to rename a component parameter. the same problem prevents faure a copy paste with the keyboard shortcuts. do you have a solution other than restarting rhino and grasshopper? is it planned to correct this bug in the next updates?
Related topics
| Topic | Replies | Views | Activity | |
| Grasshopper / Rhino UI | 3 | 584 | October 27, 2020 | |
| Grasshopper Component Name, Input/Output Renaming Fickle And Unresponsive | 2 | 352 | April 9, 2024 | |
| Rhino-Grasshopper - Can't use keyboard | 8 | 406 | July 21, 2025 | |
| Automatic text field not working | 2 | 227 | April 10, 2024 | |
| Keyboard shortcuts not recognised in Grasshopper | 31 | 3860 | September 20, 2024 |
