AlW
March 3, 2017, 11:36pm
21
…and if one of the things you can do with edit is delete the whole preselected test string - accidentally - there should be a way to get it back. Will “undo” work here?
brian
(Brian Gillespie)
March 22, 2017, 4:36pm
22
brian:
I actually think Willem’s request is pretty straightforward:
Select an existing Text object to edit2) In the properties panel, click the Bold button
Since nothing is selected in the text field, nothing becomes bold. If Rhino simply selected everything in the edit field when the properties dialog activated, or when the modal editor came up, his problem would go away.
He’s asking to get rid of the tedium of having to select the text in the editor to change the style of everything there.
RH-38206 is fixed in the latest WIP
