Text block not visible in Layouts?
I am experimenting with Layouts. I have watched @mary 's video, but it stopped before she got to annotating layouts. Somehow, I am not able to make text blocks visible in the layout screen. Lines are fine, just not text. The text block is there, it shows up in the print preview. What am I doing wrong?
I am using 5C254.
Max.
Something must have been amiss with Rhino, restarting it solved the problem.
Max.
Thanks for the update, Max.
Very odd. Let us know if you see it again.
Sincerely,
Mary Fugier
I did see it again. Text block placed: no on-screen visual result. I tried to select it with a selection window: nothing selected. However, when I place a new object in approximately the same location, the cursor snaps to the hidden text block, highlighting its outline! Very odd indeed. I will let you know if I can detect a pattern.
Max.
