I tried importing a layout from V5 that has text and the text did not show up in V6. I tried then just applying text in the layout and again no visibility.
I tried using the text command just in a normal viewport and am having the same issue. Text Object command works fine but not the text command. Is anyone else having this issue ?
If you run SelText, does anything ring up as selected?
Okay so in the Parallel viewport text is visible. In my Top Viewport, no visibility. No visibility in Layout.
SelText is working in every case.
