After latest update:
if i use Arial font for text, then after edit switch editor to Arial Black…
I have the same problem as you. When I try to modify a text, which was original “arial” font, it gets automatically changed to “Arial black”.
When I start a new file and use the text command, the style and font is in blue and gets automatically overritten:
Hi, this has been reported here as well, has been logged, and the fix will be in the next release.
Thanks.
Thank you for the information. Is it possible to say when the next release is availibe?
Will it help to install an older release?
It’ll be in the next 6.17 release candidate. I know it’s very soon but don’t know exactly when.
I don’t know in exactly which version the bug was introduced but 6.15.19161.18591 is ok.
I have the same problem. Thanks!
After latest update (25.7.) problem still exist…
Hi - from the bug report (RH-53897), it looks like the fix was merged into the “6.x” branch, which, at this point in time, is 6.18. I tested this earlier today in 6.18.19208.12051 and it works there. When SR17 is released, you will get access to the 6.18 RC.
