Text and shapes carved on mesh
Hello everybody,
I am practicing with meshes and I would like to create text and shapes on my meshes for 3d printing.
Now, the first thing I notice is that in GH I don’t have the same behavior of the Rhino function Surface from planar curves .
I am looking for a system of recognition of overlapping regions and then subtract the smaller ones to the bigger ones. At first I tried to use Collision Many\Many, but I can only isolate all the regions that collide, while I would also now the number of collision events that occur (in this case 5).
Another solution would be to call the Rhino function Surface from planar curves in GH from a script editor.
Is it possible?
Thanks for all in advance.
Giaco
text-carved-mesh.gh (187.7 KB)
For some reason, my Fabtool’s Text 3D Advanced component draws error in R6.
BTW, another plugin like wombat(Text Outlines)works just fine.
Thanks Kim,
it was simple, I did’t figure out to put a boundary surface component before the extrude.
I finally made the emboss using cocoon and a Boolean difference.
I still have a question: I would like to make closed meshes without using Cocoon :slight_smile:
I tranformed the outlines in polylines and extruded them into brep; then simple mesh all. I am stuck on searching a way for capping the text.
Playing around with delaunay doesn’t work because it has to work with any text if I change it.
Any ideas?
thanks in advance!
Hope it helps…
text-carved-mesh_re.gh (21.7 KB)
