TestSubD to Nurbs?
Hi All,
I just imported some low-poly cages from Modo in to the latest wip. I run the command TestSubD and they beautifully conver to smooth objects.
Can I convert those smooth results to numbs and open in V5? or no yet?
Thanks! (this is really exciting!!!
G
Hi Gustavo- not yet, as far as I can see - you can ask for NURBS output in testSubD, but that makes a pretty dense set of surfaces, maybe not what you are after.
thanks Pascal, that will do for now. I just want to machine something. I’ll report back!
G
Is there a comment somewhere explaining what this command does?
I saved an object out of modo as an OBJ
Imported the object into Rhino
Ran the command and got a (very nice) smooth surface
But it is a mesh surface not a nurbs surface
So I ran MeshtoNurbs but that gives me a non smooth, faceted surface.
Is this what’s expected?
Whatever, I’m very excited about this.
hi Alex,
Just like Pascal said: look at the options in the command line when running the command. The default output=LimitSurface, you can change that to nurbsSurface
