TestPackageManager crashes Rhino 6
Hi @stevebaer,
if i run TestPackageManager on Rhino 6 SR34, it sometimes crashes right away. If not i can use the search bar and when i click on the version dropdown, Rhino 6 crashes.
I understand this is a Test command. Is it no longer save to use with Rhino 6 ?
_
c.
I’m not sure; the Package Manager and associated user interface are really @will and @Trav 's domain. I’ll let them chime in and provide their opinion
hmm. I loaded up the test command in v6 this morning and did some clicking around and installing and no crashes on my end just yet. I guess we’ll need to know a few more details or maybe @will has some ideas.
Thanks @Trav, i can reliable crash RH6 still running on Win7 if i open that dialog and immediately click on that Version dropdown arrow. It does not crash if i tab to this control and press Space to drop it down.
_
c.
I can’t reproduce this either, though I’m running Windows 10. Does Rhino give you the opportunity to submit a crash report when it goes down?
Hi @will, sorry no. It just freezes.
_
c.
Hi Clement -
When Rhino freezes, you can create a dump file by going to the Windows Task Manager and picking Create dump file from the right-mouse-button pop-up. You can upload that to Rhino Accounts - make sure to mention this thread in the comments field.
In Rhino 6 Service Release 35 it seems like the package manager freezes (in my case for approx. 1 minute) after that - it seems to work
Hi Martin -
I’m pretty sure that is the expected behavior with that test command. A lot of work went into the Rhino 7 version to make that quicker.
