Temporarily hide selection highlights during a command or GB transform?
  1. Is there a way to switch it on and off during a command? Sometimes it would disturb a clear visual overview when tweaking geometry.
  2. is there an option (selected everything with Ctrl+Shift+Drag selection marquee) to hide all the points in selections? As you see it is very overwhelming with so many points.
Many thanks
Hannes
Hi Hannes -
No. There are some scripts and a plug-in that were posted in this thread:
If those are surfaces in that picture, you could, in the Filters panel, select the Sub-objects option and deselect the Control Points option.
Thank you @wim that works beautifully. All vertices gone. so annoying :slight_smile:
