Hi everyone,
I’m experiencing an issue with replicating the insertion of a rebar set using Grasshopper. In the video, I demonstrated step-by-step how to add crossing reinforcement to my strip footing in Tekla Structures. First, I select the surfaces and then the guideline. Everything appears to be fine with the reinforcement in this workflow, and the covers are applied correctly.
However, when I attempt to replicate the same workflow in Grasshopper using the Rebar Set component, I encounter problems. I select the same faces and the same guideline, but something goes wrong. On one side of the part, an additional rebar appears outside the part, while on the other side, one rebar is shorter. Additionally, the covers are not applied in this workflow.
I successfully managed to create longitudinal and crossing bottom reinforcement, but in that case, there was only one surface—the bottom of the strip footing.
