I have a wired problem with rebar inserted to tekla through grasshopper. I am inserting 2 single rebars through grasshopper and I do not know why one of it moves in an unexpected way changing ANY of Rebar Attributes. Secound bar behave allright. What could be a reasone of this behaviour?
Here is a GH file. I am using live link with Tekla. I bit modified script but problem still exists.
Beam at the begining is linked to wall created in tekla with openings. What is important- Work plane X must be set along wall.
I have made some tests and discover that sricpt works when wall is created along global X axis. When it is along Y (or it is at angle between global X and Y) problem appears. Of course every time I am adjusting work plane X axis along wall. I am workings on Tekla 2023 SP4.
@sebastian.lindholm one more thing- I tried to continue with the script for the wall along global X direction and when I am changing Atributes everything is ok, however when I am changing covers from and on plane bar follow some wired path instead of horziontal and vertical line. I have no idea why it behave like this.
Hi, still can’t replicate unfortunately, everything works well even when I try aligning the wall with the Y-axis.
I’m not sure exactly how the cover direction for a single bar is determined. Tekla probably tries to do something clever with the faces of the panel. Again I assume it follows the same path if you change the values manually? One option is to offset the points in Grasshopper instead and keep the cover thickness at 0.
I checked what is going on when I am adjusting cover manualy and it seems it works wrong same as via GH for vertical bar but for horizontal ones everything is ok. It doesn’t even matter how I place work plane.
Alright maybe try your script with Tekla 2022 if possible, to see if this is version-specific. Then support could take a look at the model if it’s indeed replicable without GH.
From a very quick test directly in TS, it seems that when I use more than two points to create a bar the cover thickness axes will be either oriented according to the current work plane, or, if the bar is placed at the corner points of a part, the axes will be aligned with the part face. But for two point bars the cover thickness axes seem to always be global XYZ - not sure why that’s not what we see in your case. Then again this was a small test.
You can rotate a bar using Tekla’s ‘Move Special - Rotate’ command but that’s not available in GH.
Bar groups are normally more deterministic as you have the range points to help determine the bar plane - maybe a group with only a single bar could be an option? Or then you offset the points in Grasshopper instead and keep the cover thickness at 0 like I suggested previously.
Thank you for sugestions. I will try to use a group probably or offset the point and in the mean time I wrote to Trimble support, so maybe they can say what is going on.
