Tekla had a new feature to define rebar - Rebar Sets which was excellent for gathering information individual rebars (get child). But, It was difficult while Cutting a rebar sets by a part, this work need to be done manually by picking in the model not to be automated. So, anyone has anyway to solving this, @sebastian.lindholm can you look over this problem properly?
This update should allow you to cut rebar sets with the Part cut and Plane cut components:
[EDIT: Latest installers on Tekla Warehouse ]
Give it a go and let me know if there are any issues!
Thank you so much for instance update. But, I was amazed that Tekla some way adapts to opening surface. Instead of using part cut, it’s just subtracting Surface which generate Rebar Sets and B-rep of desired parts in Grasshopper first then connect to Rebar Sets component. But I don’t strong imply this way, because of it changes the properties of Rebar Sets, the Boolean Part from the Rebar Set couldn’t be retained
Hi Sebastian, somehow Rebar set isn’t functioned while moving or copying into another model project. I had tried both way: published custom component, copy special from another model but neither works with Rebar set. The rebar leg surfaces weren’t carried with rebar set so its can be regenarated itself in another model. So is there any way to modification these rebar set in new model by feeding the surface in grasshopper to regenerating its?
Also Tekla has adding leg surface on direct modification section whilst selected
