Tekla multiple Grasshopper Components
I would like to spread multi parameter objects along curve in Tekla and then modify parameters (e.g. length, width) of each object manualy, directly from Tekla.
My idea was to create slab component using “Grasshopper Component” and then spread this component along curve, but I don’t think its possible.
I tried this way:
Any ideas or help? :slight_smile:
oska_czarnkow.gh (19.5 KB)
Ok i handled with this by myselft :slight_smile:. For anyone having the same problem, this is mine alghoritm:
Add manualy Grasshopper Component in Tekla model and select one Tekla Component in Grasshopper. What is important, graft output when adding multiple points of insertion. With this solution each component is unique and can be edited inside Tekla.
