Hello, I am just trying to understand how much of a use case I can justify with grasshopper.
I have created some fairly complex custom components which are all bound within tekla to workplanes and are adjusted by increasing the distance between the workplanes, within the customcomponent I have allocated names to the parameters, is there a way for me to link to those parameters via grasshopper and adjust them using grasshopper?
For exampled: A custom component spaces two beams x distance away from eachother via the use of a workplane on the centreline of each beam and is controlled within a custom component dialog box using the parameter Spacing. Could grasshopper link to that parameter and input data using a number slider?
