Tekla for Grasshopper
Hi, I am starting to link Grasshopper with Tekla, I already download the GrasshopperTeklaLink.gha but when I drag and drop that file on the grasshopper canvas,
the prohibition icon appears and does not drop the file on the canvas, Why?
You want to put the .gha file into the following folder.
%appdata%\Grasshopper\Libraries
You may then need to unblock it by right clicking the file and opening it’s properties.
Thank you very much.
I did it and now I can drag and drop, after I unblock the file gha but don t appears Tekla icon…
Exception System.IO.FileNotFoundException:
Message: Could not load file or assembly ‘Tekla.Structures, Version=2017.1.0.0, Culture=neutral, PublicKeyToken=2f04dbe497b71114’ or one of its dependencies. The system cannot find the file specified.
An error occured during GHA assembly loading:
Path: C:\Users\Francesco\AppData\Roaming\Grasshopper\Libraries\GrasshopperTeklaLink.gha
Command: Grasshopper
Appear this message on Rhinos
Looks like the tells version you have installed does not match the grasshopper plugin. There should be a tekla menu in the toolbar along with the sets. Curve and regular tabs.
