Hei,
Tekla livelink 2023 for some reason is not loading to grasshopper even when the .gha files are unblocked. Here is the error what Rhino command informs:
Hei,
Hi, that indicates it can’t find Tekla Structures 2023. Do you have that version installed or are you on an earlier version?
Cheers,
-b
Hmm, one reason might be that Tekla.Structures.Dialog.dll hasn’t been properly installed to the GAC, might be worth trying to reinstall TS in that case.
But before that you could try to locate Tekla.Structures.Dialog.dll from your TS install folder (e.g. C:\Program Files\Tekla Structures\2023.0\bin) and copy this file to the Libraries folder where you have the .gha so that the GH-Tekla link is able to find it. Or if that doesn’t work it might need to be copied to the same folder as the Grasshopper plugin or then Rhino.exe (e.g. C:\Program Files\Rhino 7\System). Not sure which if any of these locations would work, just restart Rhino/GH to see if it has any effect.
Cheers,
-b
