You seem to have at least P15 and P3 showing up in the “Deconstruct Component” output. To get the rest of the parameter names and values to show up you need insert a custom component manually into Tekla, update/modify the parameter values to something else than default and then reference this custom component into the “Deconstruct Component” component.
Note that even if the parameters don’t show up with the “Deconstruct Component” you can still set the values using the “Attributes” input of the “Component” component, for this you only need to know the parameter names as you have specified them when creating the custom component.
Hi, so you are saying that when you connect the attribute input from that “Construct UDA” component to the “Component” component the attribute values don’t get applied immediately? And you need to trigger the “Component” component again for them to take effect in the model or show up in the “Deconstruct Component”?
I tried your setup with a simple cc, and for me the values come through (and are applied in the Model) immediately the first time the “Component” component runs:
But I might not understand the issue completely, perhaps you could provide a short recording of what you’re experiencing in that case? Or share the script and custom component if you’re ok with doing that.
