Hi @sebastian.lindholm !
I have 3028 piles. Each pile is an assembly, and for each pile, I need to add a set of attributes. I know about UDA syntax, and if I add it at the part level, it will work. However, these attributes will only appear at the part level in the IFC. In Tekla, they will show in brackets “[ ]” at the assembly level, but they won’t export at the assembly level in the IFC.
If I use the Cast Unit in Grasshopper to create assemblies, Tekla crashes. Is there something wrong with the number of input data, or is there some other constraint?
I will be glad of any help.
