Hi!
I’m trying to use “Cast Unit” component in Grasshopper, but when I add more than two inputs, I get warning about adding concrete and steel parts into same assembly level. (pic.rel.)
Any ideas how to deal with this?
Hi!
If you simply click Yes and also check the box “Don’t Show this message again” you won’t get this dialog showing up again.
Hi, maybe a bit too late on this post, but im having this issue too.
No matter if I check the “Do not show this message again” box
It will appear again and again.
This dindn’t happen to me before, so a bit strange
Hi, here’s an update that should show these messages only when you’re actively trying to mix steel and concrete parts the wrong way:
[EDIT: Latest installers on Tekla Warehouse ]
Previously the message could pop up because of temporary dummy objects that had the wrong material. These dummy objects are needed to create an empty assembly that the actual objects can be put in.
As usual, let me know if anyone tries this and notices something not working as it should!
Cheers,
Sebastian
