I’ve been trying to analyse this tapered shell (drawn in Rhino) on Karamba. Grasshopper gives the correct volume but the incorrect mass of the shell (even when specifying the correct material). The only way I’ve gotten the mass to match what is expected is by adding a cross section that doesn’t actually correspond to the cross section of the model, therefore the results wouldn’t be accounting for the changing sections.
I was wondering if it is possible to map out the correct cross sections using the geometry I already have.
Thank you for your time!
shell 1.gh (51.4 KB)
wing model.3dm (250.3 KB)
