Tangent surface between two tubes
yes - see my post above. the ratio is constant in 2d - and as the angles are not vary dramatically it nearly stays the same along the given tubes / pipes…
this image in the paragraph “inner tangent” shows the triangles - marked them red / green - with same angle - resulting in constant ratio.
Innere_tangente.svg
