I have read many discussions on t-splines not available blah blah blah in rhino 6 dated back to 2018 and there just flew over my head! I am new to rhino.
All I want to know is, without your senseless jargons, what is the equivalent if t-splines is not available? If there is one, how to I get to use it?
from what i remember reading is that you can convert your limit surface geometry into nurbs (how smart that is, may generally be open for discussion in regards of nurbs topology - no matter which limit surface tool you would use) and then sure work it further in rhino 6. depending on how stable the wip 7 is you might just also finish it there. and there is a minor part of subD tools integrated into the version 6, but i really dont know which ones, not all of them thats for sure.
Hi Mark,
Are you using Xirus? If so do you like it?
I tried it very early on when it was extremely buggy…it seemed like a big learning curve coming from t-splines and I did not have the time so stopped testing it.
no worries @markintheozarks was just curious to hear from someone actually using it. I tried it early on and it looked like it was not for me…and it was really rough and buggy. I will stick with t-splines for now.
Hi Sochin,
Recall the version you were testing was actually the first WIP (= work in progress) in February 2018, i.e. not even the alpha version. (I think we did not yet even had a toolbar back then… )
…you might want to give it a try again.
–daniel
Hi Daniel,
I remember you, one of the moderators on the Xirus forums. I will keep Xirus in mind but for now I will wait for another Rhino user to rekindle my interest.
edit…@Daniel_Schmitter…just checked…not that it really matters…I stayed around for quite a few of the Alpha versions which were all still buggy IIRC…as you would expect. I stopped commenting after I found the way the tools were being laid out appeared to suit a programmer more than a designer IMO.
Glad to see you got the product to market. All the best.
