Hello Forum,
When I try to start Rhino7, I get the following exception and cannot get a license. How can I solve this problem?
Error converting value “System.Net.WebException, System.Net.Requests, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a” to type ‘System.Type’. Path ‘Lease Tokens.59ff75c9-9c71-4ef8-a290-6b590f3fc63a.LastUpdateExceptionInfo.InnerExceptionInfo.InnerExceptionInfo.Type’,
line 1, position 3510.
The same screen appears repeatedly even after Retry.
If I Cancel, the program terminates without obtaining a license as shown below.
I don’t see a license for Rhino 7 in your Rhino Account…
How did you verify my Rhino account? If you verified it with the email address registered in this forum, it was old and I changed it to the same one as your Rhino account.
I’m having a similar issue today with V7.22.22255.5001, after installing V-Ray 6… I uninstalled V-Ray and tried to repair V7 installation, but the issue is still there
I uninstalled Rhino, and installed again with the same version, but nothing works.
I have V8 wip installed and I don’t have any problem with it.
I don’t want to delete any important folder, can you help me?
I could solve the issue by opening Rhino in another PC previously used with the same email for registration. After I closed Rhino on the other PC, I could lunch V7 on the main computer.
For anyone else reading this, if you run into the same error message in Rhino 7, it can be resolved by starting Rhino 8 WIP and running the _Logout command. You should then be able to log back into Rhino 7.
