As we see it there is a problem with the Sweep2 command in Shapediver.
When we upload a model to your Platform, it does not generate the same Surface as in our local grasshopper-file. The Boolean ‘’Same Height’’ has no impact what so ever on your Servers. The command never generates a surface with same height.
I could reproduce the Sweep 2 options problem and we will look into it.
You can create the geometry as a mesh straight away which gives better performance and control over your model. Creating surfaces and converting them might also result in large meshes and we recommend alternative workflow, see this definition:
