Sweep2 for multiple curves and rails
I’m trying to use the Sweep2 component for sweeping multiple curves and rails at once.
Any suggestions on how to do it?
Thanks a lot!
SWEEP2.gh (4.4 KB)
Learn more about lists and data trees:
Designing with Lists | The Grasshopper Primer Third Edition (gitbooks.io)
SWEEP2_02_tp.gh (8.4 KB)
as @martinsiegrist wrote - you have to organize the data in the correct List and Tree structure to get combined to the desired surfaces.
see attached file.
instead of sweep2 maybe loft will be a good alternative.
kind regards -tom
Thanks. I will try to figure it out.
Loft works just fine:
1
