Some basic testing: I want the wireframe of this cube, to be used as a frame, for whatever target curve
But it doesn’t seem to work properly… and by googling I coudnt find much yet
you should provide each sweep-rail its own -in this case perpendicular- section circle
as rule of thumb with Sweep, if you have n sections and n rails:
the sweep is built on the section, regardless of where the rail is:
in case sections are Circles I would very much consider using Pipe instead (expecially for the Cap options)
the problem this way, is that if I get any complexer shape than a cube, the I should get somehow right the correct association between rail and section
I was trying this way
