I have a set of 6 curves. I want the one that is next to the surface, to be maintained for structure, ie; I want the number and placement of points to be continued along the sweep, but be able to use the other 4 curves to define the shape inside of the surface. I’ve tried surface network, extruding and matching, and sweeping in different ways to no avail. I’m trying to avoid hand editing the surface to get the curvature I need.
If you turn on the points for the 2 surfaces in the first images, they probably don’t line up, do they? The new surface has far more points than the other surface.
