Sweep 1 not working
I am trying to use sweep1 but without sucesses, I tryied ajusting the profile curve seam, but I didn’t worked. Also tried Perp Frame but it didn’t maintened the propper position of the profile curve. Anyone know what is happening?
Sweep1 Daught.gh (12.2 KB)
It’s just a way around the problem.
Sweep1 Daught a.gh (25.3 KB)
@Leo13,
Both Sweep1 and Sweep2 working fine*:
Sweep1 Daught.gh (24.4 KB)
*However, when offset is ‘positive’, Sweep1 doesn’t work:
But Loft will with both, similar to what is shown by Leopoldo.
@René_Corella @leopoldomonzani Amazing way from both! But the thing is, I need the sweep or loft (any kind of extrusion to be real) to be done in the exact point that I have put the profile curve. I am not sure how could this be done using the methods presented. Sorry I didn’t said first.
Also, I baked both solutions and they got distorted from the profile curve, as the images shows
Sweep1 Daught b.gh (23.9 KB)
instead of sweep u can extrude the section and miter joint at the corners ..
Thanks, I didn’t get what is different from the previous version, but now the extrusion matches perfectly the profile curve!
Yes, this is the approach that Leopoldo chose. I am more of a Rhino user rather than grasshopper, so the sweep seemed to be a simpler option. Didn’t know grasshopper don’t treat sweep as same as rhino.
