Hello everyone!
I just downloaded Rhino 8 to start learning before I use the program at Arch School and have been following the Rhino 6&7 intro videos. (Figure they should work mostly similar)
I am stuck in 3.1 Surfaces and Solids | Rhino3D.Education
The objective for this is to create a chair for which I have already made the guiding lines and have made the groups accordingly. (Image 1)
However when I try to use Sweep 1 to sweep the circle for the girth of the steel I can only select individual lines (Image 2&3) and even when making the sweeps independently they do not connect nor look good.
Do you have any idea about why this could be happening or upright solution?
I am just getting to know the program and this is frustrating having repeated it twice to see if anything changes.
Thanks a lot in advance!!
