I’ve been using the Rhino SVG Export more and more and here are a couple of things that I find could be improved upon.
My documents are mostly in either millimeters or centimeters, however under Scale …% the SVG Export window is always set to inches “On Paper”. Inches are not a dimension I ever use as a European. Couldn’t this simply default to 1:1 scale in document units?
The Size presets are nice, but there is no option to toggle between portrait and landscape modes. When I for instance want to export a DIN A3 in landscape mode, I first need to select the A3 preset, and manually switch the width and height values. This gets old quickly.
Regards.
