I am trying to export this selection into SVG format with solid color, not wireframe. I see that there is the option on the export menu called “raster output”, nevertheless when choosing this the file resulting is blank and 1kb.
I don’t find this problem when exporting with the vector output choice, in that case the export is perfect.
How can I make the raster output work?
@laurent_delrieu I saw that some time ago you posted regarding svg exporting.
[Uptade]
This extension I added now it appears to be working, previously I got error messages and it didn’t open Save As Scalable Vector Graphics | Food4Rhino
It takes almost a minute to open, I don’t know if that is normal (?)
Now it let me export with filling, but the image resulting is very very small, can this be changed? I don’t see the option.
Are those steps for the rhino 6 svg exporter or for the plug in?
In any of those cases, could you tell me where I can find the option: fill as solid hatches? And if possible, could you share a screenshot of the process?
I need to export 10 000 tiles by hand and I would very much appreciate the help on this.
Hello - the idea is that if you fill the tile outlines with solid hatches (Hatch command - try it on a rectangle) then svg export will export those as fills.
