I have two different Revit files. Both files have the exact same Survey Point in Revit.
When I use the component Project Location (Location) to see where are those points in Rhino, they show in 2 different locations.
What could be the reason behind this?
Japhy
(Japhy)
January 18, 2024, 6:10pm
2
Are they the same units?
I changed the category to Rhino.Inside - Revit
Yes they are the same units: mm
Japhy
(Japhy)
January 18, 2024, 7:56pm
4
If you can’t provide an example can you take some screenshot of the Project Location outputs?
something like this…
Re-SiteLocation.gh (12.5 KB)
Here you go. I have used your script to extract that information from both models.
Again, in Revit, the Survey point is the same, but in Gh is different.
Japhy
(Japhy)
January 18, 2024, 9:22pm
6
Thanks Japhy, I will check with the BIM manager and come back if the problem persist or if that is the solution.
