Been using grasshopper for a year now, but still have problems choosing the right components. I have several curves that are rotating in a same axis. They intersect between each other. And I need to make a surface that surrounds the curves using the intersecting points or the totality of curves. Its kind of urgent so I would be very grateful with an answer.
Surely not a good answer like the one from Dale, but the simpliest way will be to do it by hand if you want something quite beautiful.
The other solution is to use 3d convex hull
