How to make Curved Surface for CNC cut
Hello everybody, I have this surface in the picture below and I wanna unroll? it for CNC cut. any body knows what should i do in rhino or grasshopper ?
if you wanna rhino model i will upload.
thanks in advance
Test.3dm (234.1 KB)
Yes. Upload please; better than guessing, right?
Of course. File attached.
Your surface has double-curvature which you can evaluate by using Analyze>Surface>Curvature analysis Gaussian Auto-Range
Also see Min and Max radius.
The UnrollSrf command flattens a surface or polysurface with curvature in one direction to a planar surface. Look at: https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/unrollsrf.htm?Highlight=unroll
@m.khalili9093 Also see Squish :https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/squish.htm?Highlight=squish
And https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/smash.htm#(null)
thank you . i worked with this tools but the had no good result for my model. any other solution?
Your object has double curvature so it will not unroll or flatten without distorting. That is due to the geometry of the shape, and is not a limitation of Rhino.
I could be wrong, but I vaguely remember the Unroll, Smash and Squish do similar things but depends on how many directions of curvature.
yes. what is your suggestion. do you know any other softwares to do this ?
You can “rationalize” the surface, means re-assemble it from developable stripes. But without knowing anything about the project it is hard to say if it makes sense…
It is impossible to flatten a surface with double curvature without distortion. That is how both the physics and mathematics works.
It is the same reason part of a sphere cannot be flattened without distortion.
Splitting the surface into strips and modifying each strip so that it is developable will result in gaps between edges of the strips.
@m.khalili9093 If your design is to be cut from a flat piece of material and then formed into the desired shape you need to either use a forming method which stretches the material, or change your design.
Yes there is a flat material and then after cutting the holes ,it will formed in plan. but i didn’t understand what you said at the end? sorry for terrible English…
you mean the whole surface can not get cut at a time .?
Yes. Unless the material can be stretched or shrunken. It is the same problem as making part of a sphere from flat material.
It depends on the material and the available fabrication methods. Can you tell us a bit more about that?
@davidcockey @Jess The complete design is like this picture. they wanna cut this on a plate and then form it in order to have planner curve. does it make sense?
Not really :wink: but in general everything is possible. It is just a question if they can afford it.
What is it? A facade, simple ironwork or mirror-polished stainless steel, self-carrying?
:grinning: I didn’t design it but it is going to be an element like a sign for some where in the city.
unfortunately designer didn’t think about specifically about fabrication.
thank you @Fred_C thank you so much i didn’t know about this tool.
You’re welcome. A quick look shows longest dimension about 3.5 meters. Perhaps consider individual cut elements, shaped/bent and connected/welded. If you can provide more info maybe someone can offer suggestions. Good luck.
