Hi
How can i divide the surface(not curved surfaces) into different sections. For example giving different materials at different levels of the wall of a building?
Hi -
You’ll have to split surfaces into polysurfaces to do this.
Thank you for your reply. Is there videos or links available using this function in Rhino.
all the videos are in the help panel, open the question mark in one of the side panels then enter your commands as usual, it will display a how to step by step with a video.
you can prepare curves, lines beforehand and use these as cutters. similar to split you can also use the SplitFace command and draw lines where you want to cut within the command.
Thank you
