Surface attached to Open Brep
Good Day, I am trying to cut a solid with two cutters which are untrimmed surfaces. The first solid difference works great but when i perform second solid difference, the surface was attached to the brep? Check solid difference inside the cluster.
SolidDifference.gh (34.5 KB)
This happens to me also sometimes then I usually use BREP|PLANE component and then use RULED SURFACE. See the attached image, hope it helps.
Regards,
Kedar
SolidDifference.gh (36.4 KB)
I used Split Brep to detach the surface from the brep. Worked as well.
Ohh that’s great. I am glad that it worked out.
