I am trying to cut out the objects labeled in the GH file from the “breps” also labelled in the file using solid difference. However, the process is not cutting the objects out correctly. How can I get this to work, should I maybe use a different component like ‘brep split’ ?
solid difference issue.gh (1.8 MB)
