Hi guys.
Is there a way to suppress the zero decimal values in a dimension?
It can cause a bit of confusion once the fabricators have covered my once beautiful clean drawings in grease and slag spots.
Cheers,
Kristen
Hi guys.
Cheers,
Kristen
Hi Kristen
Try the below script in Python . At the end launches the script and all dimensions will be OK:
#-*- encoding: utf-8 -*-
# write by Vittorio carlottovittorio@gmail.com
def ToglieZeri(string):
if "." in string: # se c'è il punto nella stringa la processo altrimenti no
k=0 # flag per ciclo while
while k==0:
a=string[-1] #ritorna l'ultimo elemento della stringa
if a=="0" or a==".":
string=string[:-1] #elimina ultimo elemento della stringa se è 0 o .
if a==".":break #se il carattere è un punto blocco il ciclo
else:
k=1
return string
def selezionaquote():
rs.UnselectAllObjects()
rs.EnableRedraw(False)
rs.Command("_seldim",False)
arrdim=rs.SelectedObjects()
for dim in arrdim:
testo=rs.DimensionText(dim)
newtesto=ToglieZeri(testo)
rs.DimensionUserText(dim,newtesto)
rs.EnableRedraw(True)
selezionaquote()
Ciao Vittorio
Hi Vittorio
Thanks for your reply.
I typed RunPythonScript into the command line, and selected the .py file and ran it.
It worked perfectly.
Now I just need to work out how to attach the script to a button.
Thanks, Kristen.
