I do have the following script that generates a cutting list and I need to modify so that the generated values to remove the trailing Zeros from the values. I do need 100.5 if it that is the result but the 100.0 to be rounded to 100
# -*- coding: utf8 -*-
import Rhino
import Rhino.Geometry as g
import codecs
import sys
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
import Rhino.UI
import scriptcontext
import math
from decimal import Decimal
import webbrowser
__commandname__ = "spec"
LayersEffect = 0
DIR = {"x":(0,1,2),
"y":(1,0,2),
"z":(2,0,1)}
AXES = {0:Rhino.Geometry.Vector3d.XAxis,
1:Rhino.Geometry.Vector3d.YAxis,
2:Rhino.Geometry.Vector3d.ZAxis
def computeDims(obj):
objRef = Rhino.DocObjects.ObjRef(obj)
brep = objRef.Geometry()
edges = list(brep.Edges)
edges.sort(key=lambda edge: edge.GetLength(), reverse=True)
edge = edges[0]
adFaces = list(edge.AdjacentFaces())
faces = list(brep.Faces)
adFaces = [faces[i] for i in adFaces]
adFaces.sort(key=lambda face:face.GetSurfaceSize()[1]*face.GetSurfaceSize()[2],reverse=True)
face = adFaces[0]
faceNor = face.NormalAt(0,0)
origin = edge.PointAtStart
xPoint = edge.PointAtEnd
xVec = Rhino.Geometry.Vector3d(xPoint-origin)
xVec.Unitize()
yVec = Rhino.Geometry.Vector3d.CrossProduct(faceNor, xVec)
yVec.Unitize()
plane = Rhino.Geometry.Plane(origin, xVec, yVec)
surf = Rhino.Geometry.PlaneSurface(plane, Rhino.Geometry.Interval(0,1),Rhino.Geometry.Interval(0,1))
#scriptcontext.doc.Objects.AddSurface(surf)#!!!!delete
verts = list(brep.Vertices)
worldPlane = g.Plane.WorldXY
tMatrix = g.Transform.ChangeBasis(worldPlane, plane)
map(lambda vert:vert.Transform(tMatrix),verts)
verts = list(map(lambda vert:vert.Location,verts))
verts.sort(key=lambda vert:vert.X)
length = (verts[len(verts)-1].X - verts[0].X)*1 # added ()*1
verts.sort(key=lambda vert:vert.Y)
width = (verts[len(verts)-1].Y - verts[0].Y)*1 # added ()*1
verts.sort(key=lambda vert:vert.Z)
thickness = (verts[len(verts)-1].Z - verts[0].Z)*1 # added ()*1
return [[(length)*1,(width)*1,(thickness)*1], [xVec,yVec,faceNor]] # added ()*1
class attr:
def __init__(self, name, isEditable, isOn, valType, exportPos):
self.name = name
self.isEditable = isEditable
self.isOn = isOn
self.valType = valType
self.exportPos = exportPos
ATTRS = (attr("N",True,True,int,1),
attr("Name",True,True,str,0),
attr("Length",True,True,int,2),
attr("Width",True,True,int,3),
attr("Thickness",True,True,int,4),
attr("Texture",True,True,str,-1),
attr("Edge_L_0.4",True,True,str,6),
attr("Edge_W_0.4",True,True,str,7),
attr("Edge_L",True,True,str,8),
attr("Edge_W",True,True,str,9),
attr("Layer",True,True,str,10),
attr("Comment",True,True,str,11)
QUANT_FIELD = attr("Quantity",True,True,int,5)
QUANTITY_COLUMN_POS = 5
MAX_DIM_LEN = 2780
MAX_DIM_WIDTH = 2050
DIM_PRECISION = rs.GetDocumentUserText ("easy_cut_precision")
if DIM_PRECISION==None:
DIM_PRECISION = 0
else:
try:
DIM_PRECISION = int(DIM_PRECISION)
except:
DIM_PRECISION = 0
class Specification:
def __init__(self, attrs, details):
self.details = [] #{}
idSet = set(range(len(details)))
self.table = []
while len(idSet)>0:
curId = idSet.pop()
curDet = details[curId]
curDetails = [curDet]
idLst = list(idSet)
for id in idLst:
if curDet == details[id]:
curDetails.append(details[id])
idSet.remove(id)
self.details.append(curDetails)
self.buildTable()
def buildTable(self):
self.table = []
for details in self.details:
specRow = list(details[0].getParams())
specRow.insert(self.QUANTITY_COLUMN_POS, len(details))
self.table.append(specRow)
self.table, self.details = (list(t) for t in zip(*sorted(zip(self.table, self.details), key=lambda x: (int(x[0][0]) if int(x[0][0])>0 else 9999, x[0][10], -float(x[0][4])))))
def autoNum(self):
i = 1
for tableItem in self.table:
for detail in self.details[i-1]:
detail.N = i
detail.refresh()
tableItem[0] = i
i += 1
class SpecDialog(forms.Dialog[bool]):
def __init__(self):
self.Title = "EasyCut"
self.selected = []
self.edgeshighlightMode = -1
self.m_gridview = forms.GridView()
self.m_gridview.ShowHeader = True
self.Padding = drawing.Padding(10)
self.Resizable = True
num=0
for idx in range(len(ATTRS)):
if num == QUANTITY_COLUMN_POS:
attr = QUANT_FIELD
column = forms.GridColumn()
column.HeaderText = attr.name
column.Editable = attr.isEditable
column.DataCell = forms.TextBoxCell(num)
self.m_gridview.Columns.Add(column)
num+=1
attr = ATTRS[idx]
if attr.isOn:
num+=1
self.precision_dropdownlist = forms.DropDown()
self.precision_dropdownlist.DataStore = ['1', '0.1', '0.01', '0.001', '0.0001', '0.00001']
self.precision_dropdownlist.SelectedIndex = DIM_PRECISION
self.precision_label = forms.Label(Text = "Dimensions precision " )
self.precision_dropdownlist.DropDownClosed += self.changePrecisionVal
layout0 = forms.TableLayout()
cell = forms.TableCell(self.precision_label,scaleWidth=False)
cell.ScaleWidth = False
cell2 = forms.TableCell(self.precision_dropdownlist,scaleWidth=False)
cell2.ScaleWidth = False
row = forms.TableRow(None, cell, cell2)
row.ScaleHeight = False
layout0.Rows.Add(row)
self.m_gridview.CellClick += self.gridClick
self.m_gridview.SelectionChanged += self.gridSelChanged
self.m_gridview.CellEdited += self.gridEdited
self.m_gridview.CellFormatting += self.OnCellFormatting
self.buttonAutoNum = forms.Button(self.buttonAutoNumClick)
self.buttonAutoNum.Text = "Auto number"
self.button = forms.Button(self.buttonClick)
self.button.Text = "Export"
layout = forms.TableLayout()
layout.Spacing = drawing.Size(5, 5)
cell = forms.TableCell(self.m_gridview)
row = forms.TableRow(cell)
row.ScaleHeight = True
layout.Rows.Add(layout0)
layout.Rows.Add(row)
layout2 = forms.TableLayout()
layout2.Spacing = drawing.Size(5, 5)
cell = forms.TableCell(self.button,True)
cell2 = forms.TableCell(self.buttonAutoNum,True)
row = forms.TableRow([cell,cell2])
layout2.Rows.Add(row)
layout.Rows.Add(layout2)
self.m_linkbutton = forms.LinkButton(Text = 'Easycut')
self.m_linkbutton.Click += self.OnLinkButtonClick
self.m_donatebutton = forms.LinkButton(Text = 'Donate',Style = "right-align")
self.m_donatebutton.Click += self.OnDonateButtonClick
cell = forms.TableCell(self.m_linkbutton,True)
cell2 = forms.TableCell(None,False)
cell3 = forms.TableCell(self.m_donatebutton,False)
row = forms.TableRow([cell,cell2,cell3])
self.Content = layout
def changePrecisionVal(self, sender, e):
global DIM_PRECISION
DIM_PRECISION = sender.SelectedIndex
rs.SetDocumentUserText ("easy_cut_precision", str(DIM_PRECISION))
specification = self.spec.details
for row in specification:
for det in row:
det.setDims()
self.rebuild()
def OnCellFormatting(self, sender, e):
if float(self.spec.table[e.Row][2]) > MAX_DIM_LEN:
e.BackgroundColor = drawing.Colors.Red
def setData(self, spec):
self.spec = spec
self.m_gridview.DataStore = spec.table
def rebuild(self):
self.spec.buildTable()
#print self.spec.table
self.m_gridview.DataStore = self.spec.table
def setObjs(self, dic):
self.objs = dic
def unselectAll(self):
for det in self.selected:
det.unselect()
self.selected = []
def gridClick(self,sender,e):
row = e.Row
col = e.Column
dets = self.spec.details[row]
if col >= 7 and col <= 10:
self.edgeshighlightMode = (col - 7)%2
self.unselectAll()
if self.edgeshighlightMode>=0:
for det in dets:
det.getEdges(det.lcs[self.edgeshighlightMode])
else:
for det in dets:
det.select()
self.selected += dets
scriptcontext.doc.Views.Redraw()
def gridSelChanged(self,sender,e):
self.unselectAll()
dets = []
for row in sender.SelectedRows:
dets += self.spec.details[row]
for detLst in self.spec.details:
for det in detLst:
det.unhighlighAll()
if self.edgeshighlightMode >=0:
for det in dets:
else:
for det in dets:
det.select()
def gridEdited(self, sender, e):
row = e.Row
col = e.Column
cols = self.m_gridview.Columns
attr = cols[col].HeaderText
val = self.m_gridview.DataStore[row][col]
if attr == "N":
try:
int(val)
except:
val=dets[0].N
self.m_gridview.DataStore[row][col] = dets[0].N
rs.MessageBox("number can be only an integer")
for det in dets:
setattr(det, attr, val)
det.refresh()
self.rebuild()
def buttonClick(self, sender, e):
data = []
nameRow = []
cols = [i.HeaderText for i in self.m_gridview.Columns]
i = 0
num=0
curRow = []
while i < (len(cols)):
if i == QUANT_FIELD.exportPos:
exportPos = QUANT_FIELD.exportPos
if exportPos>0:
nameRow.append((exportPos,cols[i]))
i += 1
else:
exportPos = ATTRS[num].exportPos
if exportPos>=0:
num+=1
i += 1
nameRow = [i[1] for i in list(sorted(nameRow, key = lambda x: x[0]))]
data.append(nameRow)
for dataRow in self.m_gridview.DataStore:
i = 0
num=0
curRow = []
while i < (len(dataRow)):
if exportPos>0:
curRow.append((exportPos,dataRow[i]))
i += 1
else:
if exportPos>=0:
num+=1
i += 1
curRow = [i[1] for i in list(sorted(curRow, key = lambda x: x[0]))]
data.append(curRow)
ExportObjBBData(data)
def buttonAutoNumClick(self, sender, e):
self.spec.autoNum()
self.rebuild()
def OnLinkButtonClick(self, sender, e):
webbrowser.open("https://easycut3d.online")
def OnDonateButtonClick(self, sender, e):
webbrowser.open("http://easycut3d.online/donate.html")
class Detail:
def __init__(self, obj):
self.obj = obj
self.selected = 0
self.id = obj
attrs = rs.GetUserText (obj)
attrs = [i.name for i in ATTRS if i.isEditable]
for attr in attrs:
setattr(self, attr, rs.GetUserText (str(obj), attr))
self.setDims()
objRef = Rhino.DocObjects.ObjRef(self.id)
obj = objRef.Object()
index = obj.Attributes.LayerIndex
self.Layer = scriptcontext.doc.Layers[index].Name
def setDims(self):
# bb=rs.BoundingBox(self.obj)
# if bb:
# x=round((bb[1].X-bb[0].X,DIM_PRECISION))*1 # added ()*1
# y=round(bb[3].Y-bb[0].Y,DIM_PRECISION)
# z=round(bb[4].Z-bb[0].Z,DIM_PRECISION)
# else:
# x=0 ; y=0 ; z=0
# self.dims = [x,y,z]
self.dims, self.lcs = computeDims(self.obj)
# texture = self.Texture
# if texture in DIR:
# dir = DIR[texture]
# self.Texture = texture
# self.lcs = dir
# else:
# dir = [0,1,2]
# self.lcs = [i[0] for i in sorted(list(enumerate(self.dims)), key = lambda x:x[1])]
# self.lcs.reverse()
# self.dims.sort()
# self.dims.reverse()
# alert = "texture missing"
# x,y,z = self.dims[dir[0]],self.dims[dir[1]],self.dims[dir[2]]
# if z>y:
# self.dims = [x,z,y]
# self.lcs = [self.lcs[0],self.lcs[2],self.lcs[1]]
# else:
# x = self.dims[0]
# y = self.dims[1]
# z = self.dims[2]
self.Length = format(self.dims[0],'.' + str(DIM_PRECISION) + 'f')
# self.Width = format(self.dims[1],'.' + str(Decimal(DIM_PRECISION).normalize()) + 'f') # added (Decimal(DIM_PRECISION).normalize())
self.Width = format(self.dims[1],'.' + str(DIM_PRECISION) + 'f') # added (Decimal(DIM_PRECISION).normalize())
# string = str(self.dims[1])
# w_zeros = self.string.rstrip('0').rstrip('.') if '.' in string else string
# self.Width = format(w_zeros,'.' + str(Decimal(DIM_PRECISION).normalize()) + 'f') # added (Decimal(DIM_PRECISION).normalize())
self.Thickness = format(self.dims[2],'.' + str(DIM_PRECISION) + 'f')
def select(self):
self.selected = 1
rs.SelectObject(self.id)
def unselect(self):
if self.selected:
rs.UnselectObject(self.id)
def getParams(self):
params = []
for attr in ATTRS:
name = attr.name
params.append(getattr(self, name))
return params
def highlightEdges(self, dir):
pass
def refresh(self):
for attr in ATTRS:
name = attr.name
rs.SetUserText (str(self.id), name, getattr(self, name))
self.setDims()
for attr in ATTRS:
name = attr.name
def getEdges(self, dirVec):
id = self.id
nor = self.lcs[2]
objRef = Rhino.DocObjects.ObjRef(id)
faces = brep.Faces#doesn't work for extrusions
edges = []
for face in faces:
obj.HighlightSubObject(face.ComponentIndex(), False)
cond1 = (round(faceNor*nor)==0) #perpendicular
cond2 = (round(faceNor*dirVec)==0) #perpendicular
if cond1 and cond2:
obj.HighlightSubObject(face.ComponentIndex(), True)
def unhighlighAll(self):
id = self.id
for face in faces:
def __eq__(self, obj):
return (self.getParams() == obj.getParams())
def makeDetail(keys, objs):
if not objs: return
for obj in objs:
for key in keys:
cur_keys = rs.GetUserText (obj)
if key not in cur_keys:
rs.SetUserText (obj, key, "0", False)
else:
val = rs.GetUserText (obj, key)
if len(val)<1 or val==" ":
def main():
msg="Select polysurface objects to export data"
objs = rs.GetObjects(msg,16,preselect=True)
if not objs: return
extrusions = []
rs.UnselectAllObjects()
for obj in objs:
if rs.ObjectType(obj)==1073741824:
extrusions.append(obj)
if len(extrusions)>0:
rs.SelectObjects(extrusions)
resp = rs.MessageBox ("Selected objects will be converted to polysurfaces.\n Press OK to continue, Cancel to abort",1)
if resp == 1:
rs.Command("ConvertExtrusion _Enter")
else:
return
keys = [i.name for i in ATTRS if i.isEditable]
details = []
spec = dict([])
ids = dict([])
for obj in objs:
detail = Detail(obj)
details.append(detail)
spec = Specification([], details)
dialog = SpecDialog()
dialog.setData(spec)
Rhino.UI.EtoExtensions.ShowSemiModal(dialog, Rhino.RhinoDoc.ActiveDoc, Rhino.UI.RhinoEtoApp.MainWindow)
def ExportObjBBData(data):
filter = "CSV File (*.csv)|*.csv||"
filename = rs.SaveFileName("Save data file as", filter)
if not filename: return
file = codecs.open(filename, encoding='utf-8', mode='w+')
s = ""
for itm in data:
itm = [ i if isinstance(i, str) else str(i) for i in itm]
s += "|".join(itm)
s += "\n"
file.write(s)
file.close()
def RunCommand( is_interactive ):
main()
return 0
RunCommand(True)
