Siri
July 25, 2018, 4:37pm
1
Hi there!
I’m wondering if there is a way to remove the zero from before imperial fractional dimensions in Rhino for mac.
(Reason: the zero takes up space and crowds small dimensioned details. I have been manually changing this for way too long…)
Here is a similar thread below in the Rhino for Windows forum:
When placing a straight dimension on a small object under 1" in length, the fraction always shows a 0 followed by the fraction. For example, 0 1/2". Is it possible to have that “0” removed entirely? I played with the annotation settings but couldnt find a solution. My only current solution is to manually enter the reading.
Toby
July 26, 2018, 10:59am
2
Just a workaround: You could change the style from feet/inch to fraction and append " if desired.
Siri
July 26, 2018, 3:44pm
3
That’s actually a fine workaround. Thank you!
I’ll use that method for all smaller dimensions.
Cheers!
Rhino V6 for Mac will have “zero suppression” tools in the annotation styles definitions so this will be a bit more flexible.
Siri
July 26, 2018, 5:25pm
5
Awesome! Thank you guys so much
Zsimon
July 29, 2018, 5:10pm
6
Excellent. And we can use it between say … 2 months? :sorriso:
-Simon
We can say anything but it’s meaningless.
We won’t know know long development and testing will take until we’ve done the work. As convenient as it would be, development is done based on task completing, not based on the calendar.
