Sum list booleans: true + false = false
small question.
There is list A: containing 12 items true/false
There is list B: containing 12 items true/false
I would like to ‘add’ these list in this way, that;
true + true = true
false + true = false
false + false = false,
any suggestions?
thanks
2020-09-22 True + False = False.gh (5.5 KB)
Like this?
2020-09-22 True + False = False_re.gh (8.3 KB)
That sounds like multiplication to me. But your test data is boring! So I used @HS_Kim’s data instead:
True + False = False_2020Sep21a
True + False = False_2020Sep21a.gh (7.5 KB)
Or if you prefer Boolean results:
True + False = False_2020Sep21a2
True + False = False_2020Sep21aa.gh (8.9 KB)
You can use expression
true + true = true
true is 1 and false is 0
in your post this is wrong :
Is that not just a logical AND?
2020-09-22 True + False = False.gh (7.0 KB)
The built-in AND component has given me some grief in the past with how it handles a mix of nulls and bools… for example, if you feed in a null and a true, it will output true, so I’ve sometimes used a python implementation of the AND operator instead.
Yes this is the simplest way
