I have list of values por example 1 1 1 1 1 1 1 1 1 1
and i also have a list of true false : true true true false true true true true true true
and the index : 0 1 2 3 4 5 6 7 8 9
the index 3 is a false
is t possible for example just add a number, for example 5 only to the false or true?
The list would be like this : 6 6 6 1 6 6 6 6 6 6
You can use implicit conversions.
ANY number can be converted to a boolean, and only “0” (zero) is “false”, the other are all true, even negative.
Only “true” and “false” string text can be converted to booleans.
(EDIT: if a string text is implicitly convertible to a number, like “0.0”, “pi”, etc… GH will do a double implicit conversion string>number>boolean … like “50.37” in the pic)
Booleans can be converted to integer or number as equal to 0 (false) and 1 (true).
Knowing this you can do you logic with very few elements.
