After many hours of working with grasshopper, it becomes a little tiring having to double click, type and select components over and over. (especially for the ones you use very often, like sliders)
I was looking for a plugin that could display a pop-up menu but couldn’t find any, so I’m posting it as a suggestion:
The wheel click menu is but a repetition of the right click menu (although much fancier!), so why not replace it with a menu where a user can put as many of his favorite/ most often used components (and even ‘bricks’/ sets of components).
That way, travels of the hand from the mouse to the keyboard and back could be reduced to a minimum.
the point I am making is not having to touch the keyboard at all. With a widget like this it would be just two clicks.
e.g. I have a slider saved as a user object with values 0-360 and snaps at the quadrants. Currently I press spacebar-3-(module appears)-enter.
It would wonderful to have it on a popup menu and bring it to the canvas with just two clicks.
Incidentally, I haven’t managed yet to make axon work. the instructions are a little confusing and I’m getting some errors.
Does anyone have it installed in v.1?
I followed the instructions and it is not working.
I then tried running the .gh file in hope that if I update the database it would work. I realized it wasn’t essential.
does the old one work with Rh 6?
P.S. I just realized you are the creator. Very nice work! pls update it!
P.S.2 To the McNeel company: Hire this guy!!!
