SubD square curve extrusion bug
Hello
I’m new here and hope I’m in good section.
I see a bug with subd extrusion when I draw a square and exttude it.
Extrusion to a point : no problem
Extrusion alonga curve: no problem
Extrusion right: PROBLEM (see pict)
someone have an explication or methode do fix this ug?
thanks per adance.
esquisse extrusion subd bug extrrusion droite .3dm (159.1 KB)
laurent
Hi Laurent - I see that, thanks.
Hi Pascal
nothing new about this bug? updates change nothing.
I try with lines drawing in square form but same problem rectangle.
when the line are not exactly otho the sub d is ok , when it’s 90 degree ortho there is error.
best regards
laurent
