I tried toolbarreset. Still no subd select toolbar.
This is frustrating.
Thanks
Thanks
The subd edit toolbar is not available.
Hello - Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
License details: Stand-Alone
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 Ti (NVidia) Memory: 8GB, Driver date: 11-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.51
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2020
Driver Version: 27.21.14.5751
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21196.5001
Hello - I am not quite sure what you are looking for -there is no ‘SubD Select’ toolbar that I know of here are the toolbars that may contain what you are looking for:
Pascal,
Thank you very much for your time. The gray selection filter box is what I could not locate. As usual, the answers are obvious. Thanks again!
hey @pascal I don’t have the full set of SubD tools on my toolbar.
If I use “resetToolbar” will it
A) Fix my problem
B) Mess up my currently set/saved toolbars?
Thx
Hi Alan - toolbar reset will set the most recent (per your installation, service release) toolbar file as the current toolbar file. If you have custom arrangements or custom buttons and toolbars, these will not be in the default.rui that opens. Make sure your custom toolbar file is saved to some name other than default.rui before resetting - you can then close the new toolbar file and open your custom one, importing any toolbars you like from the default.rui.
Gotcha, thanks so much for the quick reply
