Testing out SubD…
filtering points, edges, polys, is not easy to do, compared with other software,
please look at 3dsmax,maya,blender,houdini,modo, even autocad. in order to work efficiently there needs to be a way to easily switch subobject selection modes. -
can’t figure out how any keystroke combination that allows for edge copying, extending… For example in max, you just hold shift and drag
gumball sometimes is not clear… because there are no cones at the ends, only a 2d arrow. Sometimes when you look at it is not obvious why way it is pointing, into or out of the screen
gumball has too much going on… most 3d programs you can change the gizmo depending whether you want to scale move or rotate. you can only do one of these operations at a time, so it doesn’t make sense to clutter the screen with all of them all the time. the current way, it makes it harder to select around the gumball, and you can easily click the wrong function
