Is there a command to make SubD friendly curves no longer “friendly”. In other words make all the control points directly editable? The reason this is needed is if a curve is unintentionally made SubD friendly and it needs to be edited. Two ways to unintentionally make a curve SubD friendly - Create the curve with SubDFriendly=Yes left over from from previously using the command, or use MakeSubDFriendly and unintentionally pick a curve.
Currently I use InsertControlPoint or InsertKnot and then delete the inserted control point or knot. The resulting curve is no longer SubD friendly and all control points can be directly edited. A direct method is desireable.
