Gumball Extrude SubD - please help
the help claims
" * SubD-friendly curves will be extruded into SubD objects."
I do not manage to extrude a polyline, nor a subD Friendly curve into a SubD.
I only get surfaces / Polysurface.
(Rhino Mac, Version 8 (8.6.24101.05002, 2024-04-10) on intel)
what do I miss ? - a preference ? a hotkey ?
is this a bug ?
to repeat:
draw a planar curve with for example 4 points:
_curve SubDfriendly = Yes
Gumball-Extrude…
my result - a surface
Hi Tom - I get an extrusion from this, not a SubD - (I have UseExtrusions set to make extrusions, bit surfaces)
@Joshua_Kennedy - what should happen here?
ok I have set it to “Polysurface”…
so this makes sense - gumball extrusion / surface-polysurface respects this setting…
but no subD (as the help suggests)… ?!?
It should make a SubD but doesn’t. I must have broke this while working on the closed extrude option. I’ll sort this out. I opened the issue here.
